Need Makefile for GCC in windows to compile UDFs |
December 28, 2005, 11:26 |
I'm trying to compile UDFs for Fluent using gcc compiler. Until now I've been using Visual Studio compiler and it has worked fine. But now I don't have a license for that compiler. I've read that it is possible to use gcc for the same purpose, so I've installed gcc and make (MinGW) in Windows. The only thing that's missing is the Makefile to create the UDF files. Can anyone help me. Thank you Filipe Madureira |
December 28, 2005, 11:40 |
Re: Need Makefile for GCC in windows to compile UD
Hi!if I'm not wrong you can dowload a free version of Microsoft V. Studio from Microsoft's site. Anyway to use gcc under Windows if I0m not wrong you need cgwin. Then have a look at the UDF guide for compiling manually a UDF under linux. You need linux-fluent makefile template which is stored in FLuent dicrectories.Luca
December 28, 2005, 16:08 |
gcc is for unix/linux OS, not for Window, Do what LUCA said or get a book about the C language that comes with a starter version of the compiler
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
UDFs compile with C99 instets C89 from V. Studio 6 | Vitali | FLUENT | 0 | July 27, 2007 11:57 |
Fluent doesn´t compile UDF on Windows | HSeldon | FLUENT | 4 | February 14, 2007 23:01 |
Compiling UDFs under Windows XP | Hannah | FLUENT | 3 | February 13, 2005 08:16 |
