Set gravity in UDF
Old   December 28, 2005, 07:27
Default Set gravity in UDF
Ray Hong
Dear friends,
Normally, gravity, g=9.80665 m/s2. It is very easy to do so in a source code.
Could you tell me how to set the g by using UDF?
Thank you very much in advance.
Ray
Old   August 6, 2009, 10:05
Default i have the same question
Astir is on a distinguished road
It is possible by using DEFINE_ADJUST. You can use a array e.g. gravity[2] und the command RP_Set_Real(). To use this UDF in Fluent you have to set the executive command (%rpgetvar 'gravity/x).
Kind regards
Astir is offline   Reply With Quote
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 05:31
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Gravity, UDF Source & Operating Density. HELP ME! Brian FLUENT 0 November 1, 2005 16:17
