Can I Simulate PLASMA with Fluent
Old   December 28, 2005, 07:12
Default Can I Simulate PLASMA with Fluent
Patel Amit
Resp. sir: I want to know if i can simulate PLASMA (microwave) using Fluent. Cheeeeeeeeears
Old   December 28, 2005, 07:25
Default Re: Can I Simulate PLASMA with Fluent
Ray Hong
Dear Patel,
Yes, it is possible. But you need to solve four additional equations by using UDS. It is not easy, and might take several months to do so.
Why don't you try to use your own source code?
Good luck!
Ray
Old   December 28, 2005, 08:39
Amit Patel
Extreamely happy. Yes in long run planning to do the same. But our group decides to check initial feasibility before doing the same. Kindly throw more light on the same. Cheears.
Old   December 28, 2005, 22:40
zxaar
domp be happy so soon work is not yet finished,
Old   December 30, 2005, 04:34
Amit Patel
Thanks. Which four additional equation and what is UDS.?
Old   December 30, 2005, 05:07
Ray Hong
The Maxwellian Equations.
Ray
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
How to simulate rupture disk in FLUENT tp9180188 FLUENT 0 September 19, 2009 10:24
Using Fluent to simulate DBD lamp Mark FLUENT 0 September 15, 2006 09:51
Could I simulate the HEAT PIPE use FLUENT Saturn FLUENT 1 December 6, 2004 06:00
help:how can I simulate a flame in the fluent? amir ghavidel FLUENT 0 May 15, 2002 05:28
