I've modeled vortex shedding using a time step that is 1/30 of the period of shedding(Fluent manual suggests at least 1/20) with good results. For the Re #'s and Str #'s I've been looking at this corresponds to a step of approx. 0.03 s. Yet, I've read several postings where someone is modeling a similar phenomenon, shedding from a cir. cylinder for example, and they're using a delta t aound 0.00001. Why so small?
The period of shedding and time step required for flow around cylinder in narrow channels is much less. May be these postings are for these cases.
Sounds reasonable. I've actually modeled a thin plate in a channel for different blockage ratios and found that the Str# does increase significantly, but I didn't have to decrease my time step size quite so small to capture 1/30th of the period. Thanks
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
natural convection - time step size | co2 | FLUENT | 7 | June 3, 2004 21:56 |
how to increase time step size? | co2 | FLUENT | 6 | May 17, 2004 07:25 |
