which model is suitable for natural ventilation?
Old   December 22, 2005, 15:08
Default which model is suitable for natural ventilation?
HVAC
Hello everyone
I am using fluent to simulate the ventilation in room. If the indoor air is mainly driven by buoyancy, which model I should use?
I have used standard k-e and RNG model. But it never gets to converge. I monitored the average temperature of the outlet. It began to fluctuate after about 800 steps.
My boundary condition is: velocity-inlet, outflow, and constant heat flux wall.
Could anyone give me some help?
Thanks
will
Old   December 22, 2005, 22:36
Default Re: which model is suitable for natural ventilatio
wheels
try boundary conditionsressure-inlet ,pressure-outlet,and the air is ideal-gas material
Old   December 22, 2005, 22:54
wheels
Old   December 23, 2005, 04:22
Steven
what is the boundary condition at your outlet ?
Try specifying velocity flow outlet
Old   December 23, 2005, 14:40
D.pavitran
If the indoor air is mainly driven by buoyancy?
I think the flow will be unsteady (note: this may again depend on the dimensions of your room). So, try out unsteady simulations.
I think your boundary conditions are ok. Outflow boundary condition is ok, if you are using bousinesqq assumption for modelling the density terms. ( note: bousinesqq assumption can only be used if the temperature difference between ur incoming air and the temperature of the walls or temperature inside the domain is very little). If the temperature difference is large then you have to enable incompressible ideal-gas law in the material properties and your outlet boundary condition should be pressure outlet. For more information please go through Fluent manual.
Coming to turbulence model now. If your case comes under plane wall jet (no lateral spreading) then I think RNG-K-e is ok( see Chen, Q., Comparison of different k- ε models for indoor airflow computations, Numerical Heat Transfer, 28, 353-369, 1995.)
If your case comes under three-dimesional wall jet then employing Reynolds Stress model will be appropriate,with RSM you will get pretty good results. But LES may also work well.
I am doing my thesis in indoor air flow , so if you have any more doubts contact me .
regards/
Pavitran D
Old   December 27, 2005, 21:29
Chetan Kadakia
I would guess your problem is of bouyancy, and you should model energy/ temperature. Pressure b.c.'s also seem like the way to go. If you have trouble with convergence try the k-epsilon realizable or spalart-allmarus.
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 01:01
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 11:52
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 05:19
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 11:15
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
