parallel computing problems with CPU time
Old   December 16, 2005, 06:10
Default parallel computing problems with CPU time
PAco
Hello everybody, I try to run FLUENT parallel on windows XP Pro with a dual processor -HyperThreading processors-, so in OS appear four "processor". The question is that CPU time in every PID it's very different... and I think this indicate that the work is not equal so efficiency its quite poor. Is this correct? Any comment about it? How can i fix it? thanks in advance
Old   December 16, 2005, 13:26
Default Re: parallel computing problems with CPU time
Evan Rosenbaum
Start by turning hyperthreading off. The hyperthreading algorithm may be poorly distributing the load.
Old   December 16, 2005, 13:37
PAco
Thanks a lot Evan, i'll try it and will comment how it works.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
problems with parallel computing Jiuan FLUENT 8 April 19, 2017 11:59
correction number and parallel computing psosnows OpenFOAM Bugs 5 June 17, 2013 21:56
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 18:50
