grid independence
Old   December 14, 2005, 09:07
Default grid independence
sangam
i came across a sample file, in which they used reidual term in fluent for grid independence. while most of them vary the grid size (Increasing mesh density). if any one knew about these things they are most welcome to give there comments.
Old   December 14, 2005, 11:32
Default Re: grid independence
Baicang
Hi,sangam
Grid independence check is important to illustrate the creditability of the calculation.
Generally speaking, one can select two or three sets of meshes to compare the results. You can compare velocity or other terms.
I think you could look for some papers related to this aspect. Hope it's helpful for you. Good luck.
Baicang
Old   December 16, 2005, 03:00
sangam
Thanks for response. can you give some of the papers regarding this or some web site addresses which will more helpful to me.
sangam
grid independence questions lucifer FLUENT 0 December 14, 2009 20:59
unstructured mesh grid independence for Fluent Shane Schouten FLUENT 0 October 11, 2006 17:50
Grid independence check Mattis Voss FLUENT 1 November 23, 2005 11:30
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 09:24
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
