Urgent! Help Needed
Old   December 13, 2005, 06:08
Default Urgent! Help Needed
Rucy
Dear All,
Could you tell me how to add a source term in to the Y mom. Eq.?
Could you forward me some piece of UDF program?
Thank you very much in advance.
Rucy
Old   December 14, 2005, 04:46
Default Re: Urgent! Help Needed
Column_guy
You can find it in the define menu. define->boundary conditions. A panel will open, in which there are two columns, in the right column select the zone you want to add the source. Push the "set" button and there will be a new panel. In the panel just select the source term. you will find the Y mom Eq, select the fucntion you define, that is OK.
DEFINE_SOURCE(example, c, t)
float source;
float pp, tt, xx;
pp = C_P(c,t);
tt = C_T(c,t);
xx = C_U(c,t);
source = pp*tt/xx;
return source; }
Old   December 14, 2005, 08:52
Rucy
Dear Sir,
Thank you very much.
Could you tell me how to find the related manual of Fluent, or any related information, to write UDF?
I still do not know the meaning of: (example, c, t) ?
Any way, thank you very much.
Rucy
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 16:22
help needed in Turbulent flow (URGENT) mike FLUENT 7 November 7, 2008 07:11
Urgent help needed with spray injection nick Siemens 14 June 29, 2008 19:48
Urgent Help Needed! Ken Adams FLUENT 3 September 26, 2007 00:50
urgent help needed on dpm vaishali FLUENT 3 December 18, 2006 15:20
