Question about Oscillating Flow in a Tube
Old   December 11, 2005, 01:41
Default Question about Oscillating Flow in a Tube
Ryan
All,
I am currently trying to model oscillating flow in a long tube. At the inlet I am simulating a pressure inlet with a UDF that specifies the pressure oscillation as a function of time. I am also specifying the outlet as a pressure outlet. I have simulated this for a pressure outlet that matches the inlet and with a steady pressure. When I run the model, I do not get the correct velocity profile; at 3/4 cycle the flow should reverse but this does not happen. I am hoping that somebody can help to address what I may be doing wrong. Is a pressure outlet the right boundary? Any help on this matter would be greatly appreciated. Thanks in advance.
Ryan
Validation of blood flow code in a tube vasilis Main CFD Forum 23 May 5, 2009 07:52
Flow oscillating device, FLUID141/FLUID142... BV Main CFD Forum 0 February 24, 2006 13:57
Can we define oscillating flow to outflow? zjm FLUENT 11 June 10, 2004 11:29
Flow around the microscale tube in CFX4.4 hsinluen CFX 2 December 10, 2003 21:53
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 15:20
