Spontaneous combustion or auto ignition in FLUENT
Old   December 6, 2005, 06:18
Default Spontaneous combustion or auto ignition in FLUENT
Seba
Hello everybody,
I have difficulties with modeling autoignition from hot surface. Is it possible to model it with FLUENT application?
I appreciate every help.
Regards
Old   December 8, 2005, 03:05
Default Re: Spontaneous combustion or auto ignition in FLU
Shiju G.Thomas
Auto ignition from hot surface....can u explain
Old   December 8, 2005, 12:14
Seba
Thank you for response. I have such situation: I need to model combustion (decomposition) of monopropellant. Monopropellants can be ignited by catalytic bed and high temperature concentrated in point (spark) or hot surface. Of course there are others species regarding to concern. I want to give on the surface (tube) high temperature or heat flux and observe is it possible to start the decomposition of the propellant?
Old   December 9, 2005, 00:06
Shiju G.Thomas
Fluent has options for spark ignition.For auto ignition if appropriate u can go for arrhenius rate also.
I can not achieve ignition in combustion chamber. hectordiaz FLUENT 0 June 6, 2011 06:38
How to bring about combustion in FLUENT ??? black mamba FLUENT 0 April 30, 2010 20:38
fluent combustion giorgos Main CFD Forum 0 July 30, 2003 15:14
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 12:34
internal combustion engines with FLUENT Elizabet Main CFD Forum 1 April 14, 1999 14:10
