problem in UDF's
Old   December 6, 2005, 03:11
Default problem in UDF's
sangamnath
I got this code for parabolic velocity profile.
But when i give compile option it is giving error.
I have copied "udf.h" into current directory.
code is --> ----------------------------------------------------------
#include "udf.h"
void inlet_x_velocity(Thread *t, int nv){
Face *f;
float y, xv;
for (f = thread_face(t); f ! = NULL; f = face_next(f) {
y = face_centroid_y(f);
xv = 20. -y*y/(.0475*.0745)*20.;
set_face_var(f,nv,xv);
Error being displayed in Fluent -->
cpp -IC:\FLUENT.INC\fluent6.0/src -IC:\FLUENT.INC\fluent6.0/cortex/src -IC:\FLUENT.INC\fluent6.0/client/src -IC:\FLUENT.INC\fluent6.0/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" D:\sangam\ga-file ew\fluenr_UDF\user1.cError: D:\sangam\ga-file\new\fluenr_UDF\user1.c: line 5: Face: undeclared variable ----------------------------------------------------------
How to correct this.
Old   December 6, 2005, 06:47
Default Re: problem in UDF's
RoM
You can look here. http://www.cfd-online.com/Forum/flue...cgi?read=31574 And for more questions feel free to ask.
RoM
Old   December 7, 2005, 00:38
sangamnath
I saw the link which u had mentioned.
But still i am not clear.
If possible clarify it.
Or else give me steps to compile center peaked velocity profile UDF file.
Old   December 7, 2005, 10:17
RoM
I copied the expamle from chapter 3.1.1 udf manual and added some addition comments. Hope it helps.
RoM
#include "udf.h" /* must be at the beginning of every UDF you write */
/* x_velocity is the name of your function
A thread is collection of cells or faces that have something in common. In this
case "thread" will hold the faces that belong to your velocity inlet. The "index"
refers to the variable to be set by your function. "Thread" and "index" are fluent
intern. They are passed by the solver. Only use them and dont change them. */
DEFINE_PROFILE(x_velocity,thread,index)
/* vector that holds the coordinates of a face center, ND_ND is a constant
it is 2 for 2D and 3 for 3D */
real f_center[ND_ND]; /* f_center[0]=x,f_center[1]=y,f_center[2]=z */
/* all float/double values should be declared as "real" */
/* "real will change to "float" if you compile for single precision solver
and double for double precision solver */
real y; /* y coordinate of the face center */
face_t f; /* an integer variable that is needed to for the face loop */
/* loops over all faces in the thread passed in the DEFINE macro argument */
/* You should get used to using fluent macros and not try to rewrite looping
functions. */
begin_f_loop(f,thread)
/* copy the face center coordintates to f_center vector */
F_CENTROID(f_center,f,thread);
/* get the y coordinate */
y = f_center[1];
/* and set the value for x-velocity as a function of y */
F_PROFILE(f,thread,index) = 20. - y*y/(.0745*.0745)*20.;
end_f_loop(f,thread)
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
