help needed for vof model
Old   December 4, 2005, 22:28
Default help needed for vof model
yan
I am using the Fluent VOF model to simulate a simple 2D flow between two parallel walls. The inlet is given pressure, and the outlet is ambient pressure. There is no surface tension and wall adhesion. I use the default settings for the vof model. But from the vof phase contour, I found that the filling is not good at the wall. There are many voids near the wall, which are far behind the flow front. I tried to increased the inlet pressure, reduce the time step, refine the meshes, and so on, but the problem still exists. I am wondering whether anyone has experience with such problem. Any suggestions are appreciated.
Thanks in advance.
Yan
Old   December 12, 2005, 05:53
Default Re: help needed for vof model
Paul C
Dear yan,
I am also currently doing a simulation of flow through a channel (3D) using VOF model. Can you eleborate your problem?
Regards
Old   December 14, 2005, 16:29
Yan
My problem is to simulate the spontaneous capillary flow in a horizontal channel, which also takes the wall adhesion into consideration. Can you give me your email address? Maybe, we can discuss more about the implementation of the vof model.
Best regards.
Yan
Old   December 16, 2005, 02:17
Paul_C
Dear Yan
You can email me via this address u_gly@hotmail.com
I think the wall adhesion option is available for the vof model.
Regards
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 11:36
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
3D Nonhydrostatic Model Needed Guo Main CFD Forum 13 July 19, 2001 12:17
