Adaptive Time Stepping: extrange behavior!
Old   December 2, 2005, 14:31
Default Adaptive Time Stepping: extrange behavior!
Freeman
I'm running 2D simulations of a flow over an automobile. I set up my problem as follows:
-Vel inlet from 10 to 50m/s (independent simulations with each velocity)
-I start with k-e standard, 1st order schemes in momentum, k and epsilon. Then I swich to k-e Realizable with 1st order scheme.
-Then, I run an unsteady Realizable with 2nd order scheme (because if I continue running steady simulations I don't get any convergence: ALL parameters remain fluctuating periodically: residuals, Cd, Cl...). I activate NITA and PISO options to make iterations run faster. Finally, I activate Adaptive Time Stepping (ATS) and I start with a time step of 0.001.
While the simulation runs, Fluent reduces the time step by a factor of 2, and it doesn't seem to change. If I start the simulation again with a time step of 1e-20... Fluent still reduces this step even more (and so on)!
Where is my mistake? Has anyone successed using ATS? Which was your initial time step and how did you calculate it (Formula?)?
Many thanks!
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
time stepping schemes for compressible DNS/LES shyamdsundar Main CFD Forum 0 January 15, 2010 00:15
variable time stepping text commands moe FLUENT 0 September 2, 2009 12:19
