udf for drop size distribution
Old   December 2, 2005, 04:53
Default udf for drop size distribution
Rashmi
hi all
anybody has UDF file for drop size distribution for oil-water two phase flow in horizontal pipe.
thanks Rashmi
Old   December 2, 2005, 11:11
Default Re: udf for drop size distribution
Krishna Podila
U have to get PBE (Population Balance Equations) in picture. KP
Old   December 2, 2005, 12:15
Allan Walsh
From my experience, you are probably better off to use some external means (like Excel) to make a file with drop data and then import that file as part of the set-up of the injections in Fluent.
Old   December 2, 2005, 12:21
Krishna Podila
Yes if the personnel just want the distribution its fine but what if one wants to study the case of drop break up and coalescence. Can injections handle that. Just curious to know. Thanks allan. KP
Old   December 3, 2005, 06:33
Rashmi
thanks for ur reply
it seems a good suggestion..can u elaborate this...do you have any manual or any example where this kind of import is done in fluent.
thanks again Rashmi
Old   December 5, 2005, 12:10
Allan Walsh
Sure, look in the Fluent manual for the specification of the file for injections. Should be something like xpos, ypos, zpos, uvel, yvel, zvel, etc. Make sure to include the parenthesis. I use a Windows system, and injection files can be created from Excel or even Notepad - they use the applicable end-of-file character.
Old   December 12, 2005, 00:09
Rashmi
hi Allan
u told me make a file in a excel and then import it in the fluent for injections.can u elaborate it for me like how do i write the file its better if u can send me some example files used in fluent which will be very helpful for me..iam not able to understand it clearly
thanks
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Customize Heat Flux Distribution Using UDF Ken Adams FLUENT 0 May 25, 2007 16:25
modeling drop size distribution Rashmi FLUENT 0 October 24, 2005 01:10
Particle Size Distribution with R-R fails? HP FLUENT 6 May 19, 2005 07:35
Data needed- Size & Temp. Distribution of Spray R.Sureshkumar Main CFD Forum 0 February 15, 1999 02:59
