regarding multiphase flows
Old   December 1, 2005, 07:56
Default regarding multiphase flows
Rashmi
hi all
iam simulating 2phase flow(water-oil).i have some queries: 1. is it necessary to use axissymmetric or can work with 3D? 2. while calculating the turbulent intensity we have to consider the density, viscosity and velocity of the mixture or only the water.( while specifying boundary conditions for inlet using water in drop down list ). 3.for fluid in boundary conditions panel should we use the stationary or moving reference frame.? 4.while plotting the contours how can we fix the scale of the countors for example for volume fraction of oil i want the scale from 0 to 1.
any suggestions are most welcome and appreciated Regards Rashmi
Old   December 1, 2005, 09:28
Default Re: regarding multiphase flows
HS
4.) turn off auto scale and write 0 as min and 1 as max in the countours plot panel
Old   December 2, 2005, 08:13
Vijay
Hi, Which multiphase fow model are you using? Eulerian/VOF etc. VJ.
Old   December 3, 2005, 05:39
Rashmi
hi iam using eulerian,dispersed, k-e 2 eqn, stantard wall treatment.
Old   December 3, 2005, 15:59
Krishna Podila
Dispersed k-e model is good. Its perfect. Are u working on bubbly pipe flows? Whose dat set are u validating? KP
Old   December 4, 2005, 23:07
Rashmi
yes iam using the dispersed k-e model..but iam not getting results. iam monitoring the oil/water fraction in one plane but the volume fraction is constant through out that plane in all the iterations. dont know y the pressure is varying from -ve to +ve...
iam validating my supervoisers experimental data.she has done with cfx and experiment but her results are not in very good agreement with her experimental one.
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 06:29
reading nu for multiphase flows lindstroem OpenFOAM Programming & Development 9 September 20, 2011 06:20
Free surface flows and multiphase flows Vidar Main CFD Forum 0 September 18, 2008 06:05
Editting section on Multiphase flows Sam CFD-Wiki 1 April 26, 2007 15:50
Continuity equation for Multiphase flows? discoganya Main CFD Forum 0 June 29, 2006 14:39
