how to create structured geometry
Old   December 1, 2005, 05:47
Default how to create structured geometry
Rashmi
hi all
i have to mesh a symmetry cylindrical pipe with structured meshing using gambit version 2.1.6.can any one tell me the steps for creating this . any suggestions are always welcome
regards Rashmi
Old   December 1, 2005, 06:41
Default Re: how to create structured geometry
HS
Hello!
I think it would be good to follow a tutorial on meshing in GAMBIT. Here is an example of one, where a step-by-step procedure to meshing a 2D pipe is given:
http://instruct1.cit.cornell.edu/courses/fluent/
Hope this helps!
/Henrik
Old   December 1, 2005, 07:44
Rashmi
thanx for your reply..but i have to create 3D geometry not 2D. if u have any tutorial on this plz forward. thanks again regards Rashmi
Old   December 1, 2005, 08:11
HS
If you just need to mesh a straight pipe then you can create a cylindrical volume and mesh it with the Cooper scheme (standard in GAMBIT for cylindrical volumes). I think you can figure it out with the 2D tutorial at hand.
Otherwise, there is a somewhat more complicated 3D geometry in this tutorial:
http://www.fluent.com/software/unive...ial_3/tg03.pdf
There should be no problems extracting the facts you need to create a just pipe from that, I think.
Good luck!
/Henrik
Old   December 1, 2005, 08:47
HS
I didn't see until now that you said you needed a structured mesh... Well, maybe the Cooper scheme is not any good then. Maybe someone else has a better suggestion?
/Henrik
Old   December 1, 2005, 22:38
pah
Hi everybody!
The suggestion of HS is so greate, however I think that we can get three-dimentional cylinder by using extrude command from the two-dimensional cylinder. Actually, I did not use Gambit for along time, but I think it is possible.
1. Firtly, you create 2D cylinder.
2. And then, draw a line as your design, make node number on it.
3. Finally, extrude the 2D grid based on the noded line. And we'll get 3D in Structure.
Goodluck!
pah
Old   December 1, 2005, 22:54
Rashmi
sorry i could not follow your steps of creating 3D geometry from 2D. plz elaborate thanks Rashmi
Old   December 1, 2005, 23:05
pah
Sorry about that,
However, which step that you could not do. In creating 2D cylinder or extrude command. At this time, I use the Gridgen only, therefore I'm not so sure about the extrude command, but creating cylinder in 2D is possible with structure grid. I will check it and let's you know soon.
pah
Old   December 2, 2005, 01:04
Rashmi
hi i created 2d cylinder(rectangular) and meshed it . now how to proceed to make it 3D
Old   December 2, 2005, 08:11
Vijay
Dear Rashmi,
Kindly read section 3-4.1 of the GAMBIT modeling guide. You will have to split the cylinder by creating 4 vertices on each circular face and then joining the vertex on one circular face to that on the circular face at the other end and thus create four edges. Thus ,you split the edges that circumscribe the end caps and use the resulting vertices to split the cylindrical face into four separate faces, the end faces become mappable. Vijay.
Old   December 2, 2005, 08:48
  #11
Murthy
It's quite easy to do structured meshing.
Here is the procedure just follow it for a quarter column then u can easily extend it to half column.
1. Create face by giving width,hegiht
2. Revolve that face 90 degree about axial axis, now u will get quarter cylinder. 3. Before you volume mesh it, go to mesh menu, click face mesh then click 4th icon i.e set face vertex type there u find End, Reversal, Trielement..etc. 4. Now, Selecet your inlet face in Face dropdown list and in the Type option select Trielement Type. In the Vertices dropdown list select centre vetex i mean where your two straight edged meet modify it from end type to trielement. 5. Don't modify other two vertices lying on circumference let them be end type. 6. Repeat the same for your Outlet face. 7. Do edge meshing as you need and ensure equal intervals on inlet face endges. 8. Next Face Meshing, Select your inlet and outlet faces
Elements: Quad/Tri
Type : Wedge Primitive 9.Finally Volume Meshing, Select your volume
Element : Hex/wedge
Type: Cooper and your sources will be inlet,outlet faces. u can get desired Mesh.
It should work now. Murthy
COMSOL - Create subdomain from an imported geometry FabioYM COMSOL 1 July 18, 2011 15:49
[GAMBIT] create faces inside geometry Lilly ANSYS Meshing & Geometry 11 June 23, 2011 09:34
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
