November 29, 2005, 01:01 |
reverse flow at the pressure outlet
hi friends iam solving a two phase turbulent jet(air+sand)by using mixture model of fluent.i am getting reverse flow at the pressure out let.is the change in grid size affects the flow field. plz help me
November 29, 2005, 02:16 |
Re: reverse flow at the pressure outlet
if the outlet Pressure is higher than domain pressure .you will have reverse in out let. If you have Fan in outletuse Fan boundary condition
November 29, 2005, 06:58 |
try to play with backflow conditions sometinmes it helps. KP
reversed flow in xxxx faces on pressure outlet | franzdrs | FLUENT | 8 | January 4, 2020 20:12 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! | XIAOYI LI | FLUENT | 11 | September 14, 2012 16:43 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
