November 28, 2005, 00:58 |
help:unsteady combustion
respected sir,
i have constructed a rectangular adiabatic combustion chamber. here it has the fuel inlet surrounded by the air inlet. the fuel air ratio is 1:1.the fuel velocity is 2.79m/sec and air velocity is 10.7m/sec.i am getting the temperature distributionbut as it is adiabatic after sometime the temperature through out the combustion chamber will be uniform. so i decided to carry out unsteady implicit calculation. here i am having doubt in giving the maximum no. of iterations per time step.i have read in the fluent help that it is usually between 10to20 but my solution is not converged in this range. so how should i give maximum no. of iterations and also no of time step? accepting positive response. thanking you |
November 29, 2005, 05:06 |
Re: help:unsteady combustion
its not certain to all case it may need 100 or higher iteration in every time step. if your stady state is converged check your phisical condition .
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
hydrocarbon gases + Boron particle combustion | nileshjrane | OpenFOAM | 1 | December 13, 2010 06:20 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 18:40 |
HELP:UNSTEADY DROPLET COMBUSTION | James Willie | FLUENT | 0 | August 5, 2005 17:42 |
Need Similar Combustion Tutorial as my model | Arnab | Siemens | 0 | May 24, 2005 18:23 |
