Lift coefficient
Old   November 26, 2005, 01:07
Default Lift coefficient
Man Hwan
I'm calculating airfoil flow. and I set airfoil's angle of attack zero. and I set flow's angle of attack 7 degree. While doing this calculation, Is Cd,Cl right? Do I convert Cd,Cl? or Just Do I use original Cd,Cl?
Old   November 26, 2005, 02:57
Default Re: Lift coefficient
bharat
Hi Man, The direction of lift and drag is given by the flow direction, so u have to change. hope this helps bharat
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 17:50
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 12:48
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 14:29
Help needed - lift coefficient on front/rear axle Jan Jagrik FLUENT 0 September 21, 2000 11:21
