udf parabolic velocity inlet with unsteady case
Old   November 25, 2005, 08:35
Default udf parabolic velocity inlet with unsteady case
Faruk Beyca
is it possible that you can give inlet velocity with respect to x coordinate and time
Old   November 25, 2005, 13:22
Default Re: udf parabolic velocity inlet with unsteady cas
Anindya
See the Fluent UDF manual. UDF for a sinusoidal inlet (varying with time) is given. similar to your problem.
Old   November 28, 2005, 09:13
CD
In a 2D calculation, is it possible to enforce an inletvelocity that is function of space (parabolic) and uses a table with data to calculate the magnitude of v-average in function of time? So can you load data from a profile into an udf?
Old   November 28, 2005, 15:25
faruk
I tried it but also I want to give initial velocity with respect to a parabolic function
Old   June 24, 2022, 11:45
Ahmed Abrar Shayor
Shayor is on a distinguished road
Send a message via Skype™ to Shayor
Did any of you guys find the solution to this?
Shayor is offline   Reply With Quote
3D velocity inlet UDF zumaqiong Fluent UDF and Scheme Programming 2 October 24, 2016 05:44
UDF for 3d inlet parabolic velocity profile ? shahzeb irfan Fluent UDF and Scheme Programming 10 March 28, 2016 16:00
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 07:04
Unsteady Physiological Velocity Inlet Taewon FLUENT 0 March 9, 2008 19:32
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
