Engine modelling
Old   November 24, 2005, 06:45
Default Engine modelling
Oliver Gilkes
I am trying to develope a quasi-static engine model of a single cylinder engine. I am trying to model the popet valves as solid volumes in the flow. However when i set them as volumes and then export them from gambit t fluent does not seem to see them and the flow behaves as if the valves are not there. Can you please off some advice please?
Old   November 24, 2005, 07:03
Default Re: Engine modelling
Sam Bennett
Have you made sure that the volume for the air region in Gambit doesn't include the volume containing the poppet?
Old   December 7, 2005, 13:29
shreen
Any luck with that? It is essentially what I am trying to do with my project. Maybe we could swap tips.
Old   December 8, 2005, 05:13
Oliver Gilkes
Yeah, i just ended up deleting the volumes of the popet valves, was not the solution i wanted. Going to go to fluent expert class soon to try and find out a better solution
Old   December 10, 2005, 03:19
Sachin
Hi I am also working on same type of projcet whwre aI am usisng some moving mesh anlaysis If this would be of your help let me know for the details Regards, Sachin Pagnis Phone : +9370650074
modelling a Diesel engine Arktik FLUENT 1 August 1, 2011 05:20
Engine modelling using fluent - advice nat2479 FLUENT 0 February 1, 2011 15:18
Engine modelling Wei Siemens 10 October 10, 2008 15:03
tutorial for CI engine combustion modelling Biksham FLUENT 2 February 19, 2008 05:25
modelling airflow through an inlet restrictor on a four stroke engine mike ede Main CFD Forum 0 October 8, 1999 10:06
