Problems with batch run
Old   November 23, 2005, 18:03
Default Problems with batch run
Anmol Agrawal
Hi Everyone
I need to run batch jobs but I am facing the following problem
When I type "fluent 3d -g &outputfile &" at command prompt the grapical window still shows up, in other word I can't use backgroud execution.
Would highly appreciate if someone can help.
Many thanks Anmol
Old   November 23, 2005, 20:57
Default Re: Problems with batch run
zxaar
this is how it is:
file read-case-data xxx1.cas solve dual-time-iterate yyy1 file write-case-data zzz1.cas file read-case-data xxx2.cas yes [b](comment: for discard cas dialog) [b] solve dual-time-iterate yyy2 file write-case-data zzz2.cas
for steady case i think it will be solve iterate yyy1 but i am not sure, my case was unsteady. hope it helps.
problems with LES run Tim CFX 1 February 27, 2006 08:28
writing a batch for a parallel run M CFX 4 December 15, 2005 01:09
data output from batch fluent run Wang FLUENT 4 March 11, 2005 12:01
Batch Run Ogbeni CFX 4 October 15, 2003 13:33
CFX-Post batch run error KG CFX 15 November 21, 2002 10:52
