Grid independence check
Old   November 23, 2005, 11:28
Default Grid independence check
Mattis Voss
Hello, I made a model of a 7 blade turbine cascade. I then wanted to check for grid independence of the solution, so I created two different grids: one where only the middle blade has a structured grid surrounding it, and the other with a structured grid across the central blade channel - the surroundings in both cases are tri-paved. My question is: what kind of measure is typically used to check for grid independence? Do I just look at the two velocity/pressure fields by eye to see if they look similar? Or should I check if boundary layer velocity profiles are similar? Or is there some measure/mechanism in Fluent that will do this check for me? Thanks for any help, Mattis
Old   November 23, 2005, 11:30
Default Re: Grid independence check
Mattis Voss
I'm very sorry for posting that twice. I thought it had not worked the first time. Apologies, Mattis
Grid independence and prismatic layer, a doubt franco-bosi Main CFD Forum 0 December 15, 2010 12:53
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 11:11
grid independence questions lucifer FLUENT 0 December 14, 2009 20:59
Fluent Grid Check: Left-handed & right handed face Haider FLUENT 3 March 23, 2009 00:01
grid check in FLUENT wan aizon FLUENT 4 January 20, 2006 05:33
