Grid independence check
Old   November 23, 2005, 08:31
Default Grid independence check
Mattis Voss
Hello, I have made a 2-D model of a 7-blade turbine cascade. To check for grid independence, I created two different structured grids, one around only the middle blade, and one across the central blade channel (the surrounding areas are tri-paved). My question is this: what kind of measure is typically used for grid independence? Do I just compare the velocity/pressure fields by eye? Or would I compare some boundary layer velocity profiles? Or is there some measure in Fluent that will do it for me? Any help would be much appreciated. -Mattis
Grid independence and prismatic layer, a doubt franco-bosi Main CFD Forum 0 December 15, 2010 12:53
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 11:11
grid independence questions lucifer FLUENT 0 December 14, 2009 20:59
Fluent Grid Check: Left-handed & right handed face Haider FLUENT 3 March 23, 2009 00:01
grid check in FLUENT wan aizon FLUENT 4 January 20, 2006 05:33
