November 21, 2005, 11:05 |
Advise with a wheel simulation
Hi all (again)!
Which is the best way to simulate the folw over a car wheel (in 3D)? I know some issues with the contact wheel and ground: it cannot be tangent, there must be a "contact patch". But if there is this contact patch, the simmetry does no longer exist, so I can't rotate the wheel mesh... what can I do? I only have an idea, and it is about to say Fluent that the tire and the rim "walls" have a velocity (a rotation). And what about with the "roughness" of the tire? |
November 21, 2005, 16:15 |
Re: Advise with a wheel simulation
Hi Freeman,
Hope this helps, you dont have to use a moving mesh. Just define your 3D wing as a wall, and in boundary conditions define it as a spinning wheel. Yes, make sure you get the angular velocity right which you calculate from a formula based on your wheel radius and linear velocity. The only problem you might have is to get a converged solution. The damn thing hardly converges! Hope this helps and good luck! Alan. |
November 21, 2005, 17:25 |
Thaks for your answers, Alan!
OK, there's only one more question. How can I represent the roughness of the wheel in a realistic way? What roughness value did you use in your simulations? As far as I can remember, I think that there are some turbulence models in Fluent that the roughness is disabled (RSM and other one I think): in these cases, is there any possibility to simulate tire's roughness? Many thanks! |
November 22, 2005, 05:42 |
Hi Alan,
To be honest, I wouldnt worry about the tire roughness at this stage since it can cause even more turbulence and there is no such turbulence model that can handle that. Use the default values, get some initial values and try playing with different roughness values of your choice. Depends how much accuracy are you after! Thanks, Alan. |
November 22, 2005, 11:00 |
OK! Thanks for all Alan. Bye!
paddle wheel simulation | s_saleh | FLOW-3D | 3 | May 12, 2017 16:51 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 09:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 19:57 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 14:46 |
