November 20, 2005, 11:08 |
automatic meshing problem
Hi, i have tried to code an automatic mesher which outputs a gambit neutral file. The file can be read into gambit but at some faces, there seems to be extra walls that are there especially between brick and tetrahedral elements.
not sure if anyone can help, just trying my luck. i suspect that it is due to my node assignment in the element connectivity portion of the neutral file. thanks |
November 21, 2005, 00:37 |
Re: automatic meshing problem
realise that there is no connectivity between my hexahedral elements and tetrahedral elements. any idea how to rectify this?
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 19, 2023 00:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 08:21 |
[ICEM] Automatic meshing | acoustica | ANSYS Meshing & Geometry | 1 | January 11, 2011 12:20 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 11:09 |
Problem with meshing long, thin faces in CFX | Martin | CFX | 3 | January 8, 2009 21:51 |
