Which viscous model?
Old   November 20, 2005, 10:18
Default Which viscous model?
Ali
Hi Would you please tell me which turbulent model (in the viscous panel of fluent program) should I choose for highly internal compressible flow, for example for a gas flow through a pipe under high pressure gradient?
Old   November 22, 2005, 05:01
Default Re: Which viscous model?
nasser
Plz explain compelet mach number? do you want model combustion? its dependent your problem
Old   November 23, 2005, 13:43
Ali
Well actually i'm modelling the flow of very high pressure gas in a tube which it the mach number shouldn't be above 1. The gas is stagnant in a vessel and then accelerate through the pipe to the atmosphere. The pressure ratio is almost 300 with no combustion. Thanks a lot
Old   November 24, 2005, 03:55
nasser
Hi Then you use K-epsilon Model Its suiteble for your problem. Mesh generation is important in Wall treatment. Good luck
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 01:01
RNG k-epsilon viscous model abaqus213 Main CFD Forum 1 May 20, 2009 00:11
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
