I use VOF model to track the free surface shape of a rough metal surface when it is melting. The initial surface shape of the molten pool is not regular. In adapt region, there are only three shapes: Quad, circle and cylinder. I cannot patch liquid phase to the region that I want. Any suggestion will be appreciated!! Thanks a lot!
I think an udf is the only way to do this. You can use a user defined memory to "mark" all the cells (set it to 1 for marked cells and zero for others) you want to patch. Then use the adapt->iso-value panel to mark all cells with udm=1.
RoM |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
