S-A Turbulence Model and drag prediction
Old   November 15, 2005, 18:48
Default S-A Turbulence Model and drag prediction
Alan
Dear All,
Just needed everyone's opinion on the use of the S-A turbulence model for drag prediction of airfoils.
I have used the S-A model for predicting Lift Coef.. at different angles of attack and the results are very close to the wind tunnel results, however I havent had luck with the Drag Coef.. values?
Which turbulence model would predict Drag as nicely as the S-A does lift?
Many thanks in advance.
Alan
Old   January 11, 2016, 07:47
sandy
fuzzylogic is on a distinguished road
Dear Alan ,
as compared to Cl , Cd are more sensitive to grid refinements .
Also , S-A is not very accurate (compared to k-w SST ) in resolving the flow separations, that may be occurring at high AOA.
You can refine the mesh using Prism elements at boundary layer and use a combination of RANS models with first order and second upwind schemes to save computational resources.
Hope that Helps !
fuzzylogic is offline   Reply With Quote
Old   January 11, 2016, 09:33
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
The threads you are replying to are very old. For instance this one is 11 years old.
shereez234 is offline   Reply With Quote
twoPhaseEulerFoam: turbulence on produces instability of drag phase florian_krause OpenFOAM 1 October 11, 2013 10:02
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
drag coeff to high - kOmegaSST turbulence model RugbyGandalf OpenFOAM 5 February 22, 2011 03:35
multiphase model and drag law Yasmail AKARIOUH FLUENT 0 April 29, 2008 08:44
Please help a newbie find the drag on a 3d model David Amer Main CFD Forum 1 March 6, 2002 04:33
