non-positive volumes exist
Old   November 14, 2005, 15:04
Default non-positive volumes exist
DavidC
after creating a 2d cylinder within Gambit, i transfered the mesh into fluent and ran a grid check which failed and i also recieved a message saying "non-positive volumes exist" and "non-positive face area exists".
any suggestions? thanks
David
Old   November 14, 2005, 15:08
Default Re: non-positive volumes exist
Jeremy
Did you take a real close look at your mesh in Gambit? Check for areas where the lines of the cells may have crossed. I have had that happen when meshing an area with a strong curvature and tried fitting a mesh to a boundary layer. Also check the mesh quality in Gambit, and identify the areas with the most skewness.
Old   November 15, 2005, 07:57
Jason
Are you axisymmetric? If so, then the axis of rotation has to be coincident with the x-axis, and your entire grid must be above the x-axis.
Hope this helps, and good luck, Jason
Grid check failed (non positive volumes). Muhammad Usman Qureshi FLUENT 5 September 26, 2013 07:26
[ICEM] Non-Positive Volumes Exist: Importing to FLUENT VT_Bromley ANSYS Meshing & Geometry 8 April 28, 2012 12:01
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
non positive volumes exist Moke FLUENT 1 July 7, 2006 09:20
non positive volumes pankaj shukla FLUENT 4 December 6, 1999 10:42
