November 12, 2005, 19:59 |
Help, UDF and define the surface reaction
CO and O2 flow through a pipe with diameter of 1mm, and the pipe is defined as a porous region. CO oxidation with O2 only takes place on the surface of the solid. Can anyone tell me how to define the surface reaction? The reaction rate is power law rate,namely, -r=A*exp(-Ea/R/T)*Cco^(-0.5)*Co2^1.2.The gas velocity is 0.17m/2.Thanks very much
October 23, 2022, 10:07 |
ccq
Have you written this code already? I'm doing the same reaction now and have a question for you.thank you!
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
udf define property on a wall surface | bzhu | Fluent UDF and Scheme Programming | 1 | November 27, 2011 11:10 |
UDF carbon conversion | papteo | Fluent UDF and Scheme Programming | 1 | August 18, 2011 07:32 |
Reaction Rate in UDF | mahdi | FLUENT | 2 | August 7, 2007 08:31 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
