November 12, 2005, 17:08 |
Floting operating pressure
Hello I am trying to model pumping water into a closed environment. As it is obvious the temperature increases as the pressure increases in the chamber. In fluent when I chose water as material and set it up the change of rho with pressure using a UDF the "floting operating pressure" option dissapears. It shold be there since there is pressure differences. It appears when I switch from my UDF to ideal-gas conditions, which is a very poor assupmtion to my model. Can anybody look at this case and give me a hint in what I am doing wrong? I am working with water as a material and reaching high pressures as 200 to 300 MPa Thanks in advance Edwardo
Operating Pressure and Cd | micvm | FLUENT | 0 | March 25, 2011 00:36 |
OPERATING PRESSURE | manish | FLUENT | 6 | February 25, 2011 05:40 |
Operating Pressure (Natural Convection problem) | Andrew Tress | Main CFD Forum | 1 | July 3, 2006 17:00 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
floating operating pressure | Shankar | FLUENT | 1 | January 30, 2004 05:08 |
