Specified Operating Density for Compressible VOF
Old   November 12, 2005, 13:01
Default Specified Operating Density for Compressible VOF
Andrew Wick
I am modeling an object falling into water. The air is compressible and the water is incompressible. Under Specified Operating Density, should I be inputting the density of air, or zero?
One section of the Fluent manual says to input the density of the lowest phase. The section under the inclusion of body forces says that if any phase is compressible, I should input zero.
However, when I do so, I get very different results. The drag curve is very oscillatory for operating density of zero, and it is not for an operating density of air. Which is more accurate?
Thanks, Andrew Wick
Old   November 14, 2005, 05:58
Default Re: Specified Operating Density for Compressible V
edi
Try enabling the "floating operating pressure" option and simply don't specify any operating density in the operating conditions panel.
Hope it helps
Edi.
operating pressure and operating density phil FLUENT 5 November 7, 2017 18:02
VOF - operating density JSM FLUENT 2 July 2, 2007 01:35
buyoancy and operating density Zeh FLUENT 2 March 24, 2007 08:22
operating density in buoyancy driven flow Marie-Anne Main CFD Forum 2 March 24, 2006 10:52
Warning 097- AB Siemens 6 November 15, 2004 05:41
