DPM and swirling flow
Old   November 9, 2005, 10:15
Default DPM and swirling flow
Vix
Hello all.
I wonder if someone can help me? I am having problems with simulating a swirl burner that uses liquid fuel. I can simulate the flow just fine and I am able to get a recirculation zone in front of the burner as expected. The problem starts when I inject fuel droplets in the recirculation zone. My residuals go crazy, and no matter how big interval between the DPM iterations it doesn't normalize. I seem to be getting very large gas phase velocities in the same region.
I have tried smaller fuel droplets velocities, smaller under-relaxation factors for Discrete phase, but nothing works.
Has anyone had experience with that kind of problem?
Thanks in advance,
Vix
Old   November 9, 2005, 10:36
Default Re: DPM and swirling flow
RoM
Try a small urf for density, density 0.5 and dpm 0.2 usually works fine. Do you have your own reaction kinectis?
RoM
Old   November 10, 2005, 03:43
Vix
Urf is under-relaxation factor right? OK, I'll try. I am not using reaction kinetics but equilibrium chemistry (PDF look-up tables)
Are you working on a similar problem?
ViX
Old   November 10, 2005, 03:53
RoM
If you use your own kinetics it could lead to numerical problems due to stiff chemistry but with equlibrium pdf this should not happen. I did some coal combustion recently and it worked well with underrelaxation 0.5 for density and 0.2 for dpm.
Good Luck, RoM
Old   November 10, 2005, 05:28
Vix
I seem to be getting a divergence even if I exclude reactions, just the interaction of discrete phase and continous phase is a problem.
Thanks for your advice!
Old   November 11, 2005, 03:17
Wouter Harteveld
Did you try a smaller particle mass flux? You may want to increase that in steps.
Old   November 11, 2005, 05:56
Vix
I am getting better results with a much lower mass flux, thanks, but still no convergence.
Could this also be a problem of the Lenght scale in the DPM panel? How does this affect residuals.
Vix
Old   November 11, 2005, 06:33
RoM
Sometimes fluent will calculate very large dpm concentrations, usually in the area of the dpm injections. You can use the adpat->iso value panel to calculate the max dpm concentration in your domain. If its close to your liquid fuel density (or even larger) you will get a problem with convergeance.
RoM
Old   November 11, 2005, 08:37
Vix
And how do I resolve this problem with a very high concentration?
Old   November 11, 2005, 09:25
RoM
There is no general solution to this problem. Your injection should enclose a large number of cells so the total mass flow is spilt. Dont use single injections or small group/cone injections for high mass flow rates. Use surface injections with fine surfaces meshes instead.
RoM
Old   November 13, 2005, 06:46
  #11
Vix
Thank you for your very helpful remarks and advice.
I' ll try to remesh my model and redistribute the DPM source and increase the number of particles in a group.
ViX
Old   November 14, 2005, 04:51
  #12
Wouter Harteveld
What also helped for me was to do 1 DPM iteration per continuous phase iteration (otherwise residuals oscilalte), and to create a decent initial velocity field by creating a gas velocity inlet with the spray droplet velocity at the same spot.
Wall function for DPM needed AMusteykis FLUENT 0 January 13, 2010 16:02
DPM slow evaporation Vix FLUENT 3 November 30, 2005 14:38
Problem with DPM model cwflying FLUENT 5 January 31, 2003 12:25
