November 9, 2005, 00:02 |
BC's for free flows
When creating the geometry and setting the boundary conditions (BC's), what is the best one to use? I have seen symmetry, pressure far field and pressure inlet. Also I have used walls and specify the shear as zero. Is it a case of "depends on your problem?".
For example if i want to model a spray from any nozzle into the open still air, would you use symmetry or pressure far field or even pressure inlet? Thanks |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 12:58 |
SIMPLE pressure correction in compressible flows | Maarten de Jong | Main CFD Forum | 7 | April 30, 2012 03:23 |
Free surface flows and multiphase flows | Vidar | Main CFD Forum | 0 | September 18, 2008 06:05 |
BCs for Pressure Correction Equation (SIMPLE) | Bharath Somayaji | Main CFD Forum | 1 | March 1, 2006 07:12 |
Need Assistance: BCs for k-e model implementation | Dean Schrage | Main CFD Forum | 3 | August 11, 2001 02:02 |
