November 8, 2005, 11:28 |
problem: very high turbulent viscosity ratio
Dear FLUENT-expert,
I do an open channel simulation (VOF) downstream a water power plant. The calculated velocity field seems sensible. There is a problem with the turbulent viscosity ratio (TVR) however. It is very high and is limited by FLUENT automatically to 100.000 in approx. 1.500 out of approx. 100.000 cells. I've read in the user's guide that the TVR should be < 10 in external flows. My results are far from this. Any ideas why this is so and how to reduce TVR? Thank you! Christine |
November 8, 2005, 13:10 |
Re: problem: very high turbulent viscosity ratio
Make sure your turbulent initialization is not k=1 and epsilon=1 but something more sensible.
November 9, 2005, 08:23 |
Hello Christine.
Sometimes this limitation occurs due to bad mesh geometry. So maybe refining/coarsing the mesh will help. Regards Martin |
Turbulent viscosity Limited to viscosity ratio | Adrian | FLUENT | 12 | September 21, 2011 05:22 |
High turbulent viscosity, problem with BC | Narmin | FLUENT | 2 | May 8, 2007 04:17 |
Turbulent viscosity limited to viscosity ratio... | Cyril | FLUENT | 8 | February 7, 2006 21:34 |
Aspect Ratio at high turbulent and swirled flows | zago | FLUENT | 0 | May 19, 2004 03:37 |
On limiting to turbulent viscosity ratio! | varghese | FLUENT | 2 | November 15, 2003 09:56 |
