Difficulty in generating 3-D mesh
Old   November 8, 2005, 08:22
Default Difficulty in generating 3-D mesh
Rucy
Dear All,
I am try to generate a 3-D mesh.
The geometry is a little bit complex. The is a large object, and another one with a very narrow width.
Could you tell me how to generate the mesh?
Thank you very much.
Rucy
Old   November 8, 2005, 12:10
Default Re: Difficulty in generating 3-D mesh
Jeremy
Mesh the large object and the small object separately.
You need to give more details if you expect anyone to be able to give you constructive help.
Old   November 10, 2005, 01:16
Rucy
Thanks, Jeremy.
But if the two parts happened to be one object, and you have to generate mesh for the two parts together, what to do?
Should we mesh the line of the object first, then generate the mesh of the 3-D object?
Best regards.
Rucy
Old   November 10, 2005, 10:53
Jeremy
Yes, you can mesh the lines first, this way you have lots of control over the distribution of the nodes. You can then mesh some of the faces, which will also give you control for the final mesh size. Then finally you can mesh the whole object as one.
You can also split your geometry into 2, one for your smaller object and one for your larger object, and mesh them separately if you are having trouble meshign them together. There is a panel to define zones, simply define the two volumes as the same zone, and when imported into Fluent, they will come in as one volume.
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Generating Mesh for Decoupled Mesh Motion with ICEM Julian K. ANSYS Meshing & Geometry 0 October 18, 2011 16:54
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
