UDFs error
Old   November 7, 2005, 23:09
Default UDFs error
Shuailin
Hello. I'am studying UDFs. And now I need to set a surface reaction. The reactants flow through a hollow pipe with diameter of 1mm, and the reaction takes place on the wall. First I'd like to understand the program about surface reaction(SR)in the fluent UDFs help document. I copied the program code into the VC++, and saved it as exampleSR.cpp file. When I compiled in the fluent, an error appeared: "line 9: function returning float returns double" The code is "real arrhenius_rate(real temp) { return PRE_EXP*pow(temp,BETA)*exp(-ACTIVE/(UNIVERSAL_GAS_CONSTANT*temp)); }" I tried to change "real" into double, then another error "THREAD_STORE: undeclared variable" appeared. The corresponding code is "DEFINE_SR_RATE(arrhenius,f,fthread,r,mw,yi,rr ) { *rr = reaction_rate(F_C0(f,fthread),F_C0_THREAD(f,fthrea d),mw,yi); }" There is not the variable of THREAD_STORE. How to solve the problem?
The whole program code is the follow: /************************************************** *****************/ /* UDF for specifying a custom surface reaction rate * /************************************************** *****************/ #include "udf.h" /* ARRHENIUS CONSTANTS */ #define PRE_EXP 1e+15 #define ACTIVE 1e+08 #define BETA 0.0 real arrhenius_rate(real temp) { return PRE_EXP*pow(temp,BETA)*exp(-ACTIVE/(UNIVERSAL_GAS_CONSTANT*temp)); } /* Species numbers. Must match order in Fluent panel */ #define HF 0 #define WF6 1 #define H2O 2 #define NUM_SPECS 3 /* Reaction Exponents */ #define HF_EXP 2.0 #define WF6_EXP 0.0 #define H2O_EXP 0.0 #define MW_H2 2.0 #define STOIC_H2 3.0 /* Reaction Rate Routine that is used in both UDFs */ real reaction_rate(cell_t c, Thread *cthread,real mw[],real yi[]) { real concenHF = C_R(c, cthread)*yi[HF]/mw[HF]; return arrhenius_rate(C_T(c, cthread))*pow(concenHF,HF_EXP); }
DEFINE_SR_RATE(arrhenius,f,fthread,r,mw,yi,rr) { *rr = reaction_rate(F_C0(f,fthread),F_C0_THREAD(f,fthrea d),mw,yi); } real contact_area(cell_t c, Thread *t, int s_id, int *n) { int i = 0; real area = 0.0, A[ND_ND]; *n = 0; c_face_loop(c,t,i) { if(THREAD_ID(C_FACE_THREAD(c,t,i)) == s_id) { (*n)++; F_AREA(A, C_FACE(c,t,i), C_FACE_THREAD(c,t,i)); area += NV_MAG(A); } } return area; }
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
user defined function cfduser CFX 0 April 29, 2006 11:58
