November 7, 2005, 10:44 |
degassing problem
Does anybody have an idea how to set the degassing problem in a vertical tube bend? The flow occurs only due to gravity and initially liquid contains quite large amount of non-condensable gases (up to 10 volume percent). I tried to use mixture model but probably due to non-correct boundary conditions I failed to get any results. Many thanks in advance |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 09:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
