Problems with text command interface of Fluent |
November 7, 2005, 04:43 |
I want to use Fluent (6.2) in a parallel environment, starting the job with a script file containing all the necessary commands to set up the case. The problem I encounter is with the initialize-flow command: When I use it the first time, I get a segmentation violation fault, but Fluent continues to work. When I enter the same command again, the initialization takes place without the slightest complaint. If I used a single processor machine only I would not be bothered at all, but when using a parallel machine, this segmentation violation causes the jobs on the other processors to crash. The following is my script file: --------------------------------- #!/bin/bash /opt/fluent/6.2.16/Fluent.Inc/bin/fluent 3ddp -g -64 << EOFluentInput > test.log file/confirm-overwrite n file/read-case test.msh grid/scale 0.001 0.001 0.001 surface/plane-slice y_0 0 1 0 0 define/models/solver segregated yes define/models unsteady-1st-order yes define/models/viscous ke-standard yes define/models multiphase vof 2 geo-reconstruct 0.25 yes yes yes ;define/models multiphase vof 2 implicit yes define/materials copy fluid water-liquid define/phases/phase-domain phase-1 luft yes air define/phases/phase-domain phase-2 wasser yes water-liquid define/operating-conditions gravity yes 0 0 -9.81 define/operating-condition operating-pressure 101325 define/operating-condition reference-pressure-location 0.1 0 0.1 define/operating-condition operating-density yes 1.225 define/boundary-conditions pressure-inlet einlass_unten mixture yes no 0 no 0 no yes yes no 1 no 1 define/boundary-conditions pressure-inlet einlass_unten mixture yes 1 yes yes 0 -4.8 no 0.001 no yes no no no yes 10 6 define/boundary-conditions pressure-inlet einlass_oben mixture yes no 0 no 0 no yes yes no 1 no 1 define/boundary-conditions pressure-inlet einlass_oben mixture yes 1 yes yes 0 -4.8 no 0.001 no yes no no no yes 10 6 define/boundary-conditions pressure-outlet auslass_oben mixture yes no 0 no no yes yes no 1 no 1 define/boundary-conditions pressure-outlet auslass_unten mixture yes no 0 no no yes yes no 1 no 1 define/boundary-conditions pressure-outlet auslass_oben mixture yes 1 yes 0 -4.8 no no yes no no no yes 10 6 define/boundary-conditions pressure-outlet auslass_unten mixture yes 1 yes 0 -4.8 no no yes no no no yes 10 6 solve/set discretization-scheme pressure 13 solve/set discretization-scheme mom 0 solve/set discretization-scheme k 0 solve/set discretization-scheme epsilon 0 solve/set p-v-coupling 22 solve/set piso 1 1 yes solve/set equations flow yes solve/set equations ke yes solve/set equations mp yes solve/set under-relaxation body-force 1 solve/set under-relaxation density 1 solve/set under-relaxation epsilon 0.8 solve/set under-relaxation k 0.8 solve/set under-relaxation mom 0.7 solve/set under-relaxation pressure 0.3 solve/set under-relaxation turb-viscosity 1 solve/monitors/residual convergence-criteria 0.001 0.001 0.001 0.001 0.001 0.001 file/autosave data-frequency 1 file/autosave root-name test file/autosave overwrite-existing-files yes file/autosave max-files 2 solve/init/compute-defaults pressure-inlet einlass_oben mixture solve/init initialize-flow solve/init initialize-flow yes adapt/mark-inout-hexahedron yes no 0 24 -4 4 -4.8 0 solve/patch wasser ( ) 0 ( ) mp 1 file/write-case test.cas file/write-data test.dat solve/set/time-step 0.001 solve/dual-time-iterate 100 500 file/binary-files y file/confirm-overwrite n exit y EOFluentInput ------------------------------------------------ I hope this is not too detailed though ;-) Any ideas? Thanks in advance for any advice! P.A. |
November 8, 2005, 13:28 |
Re: Problems with text command interface of Fluent
Sorry, I have nothing useful to offer in re this problem. But I had to write because it appears you are a rare example of someone writing significant .jou file programs. I do almost all my CFD work this way and wonder what resources you used to get proficient at this, and what tips you have to share. Writing .jou files seems very difficult to me, because of all the experimenting necessary to discover the text prompt questions each line must answer, and especially because the questions are often state-dependant in ways one might not anticipate.
How have you managed? Do you have any resources you'd care to share, beyond the docs available from Fluent? Thanks - and sorry I wasn't any help! |
November 9, 2005, 08:25 |
Unfortunately I do it exactly the same way you described. It took me lots of hacking through the TUI menu to find the entries I am used to see in the GUI. What seems most crucial to me is that many settings in the TUI can not be made at the same "menu" position like in the GUI, which is really confusing sometimes. The worst thing is, that there seems to be no appropriate documentation on this scripting stuff. I am sorry that I can be not really helpfull on this!
Cheers, Pascal Anschau. |
problems with Fluent display windows | chris | FLUENT | 3 | January 7, 2016 11:44 |
Fluent Convergence Problems | Vidya | FLUENT | 24 | January 1, 2016 14:01 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 14:43 |
solving of multi phase problems using fluent | satyanarayana | FLUENT | 3 | November 20, 2009 17:37 |
Problems with the UDF in Fluent | Mathew | FLUENT | 1 | February 26, 2008 20:15 |
