Furnace wall heat exchange
Old   November 3, 2005, 13:20
Default Furnace wall heat exchange
Andrea
I have to simulate a burner in a furnace. How I must set the boundary conditions on the furnace wall. In the reality, I have a wall of about 30mm in ceramic fiber. When I simulate, the furnace temperature is about 2500K, but in the reality I have 1250°C.
Shell coduction? Temperature? Heat transfer? Help please!
Andrea
Old   November 3, 2005, 13:45
Default Re: Furnace wall heat exchange
Allan Walsh
Many factors will influence the predicted temperature including fuel specification, way in which combustion is calculated, gas specific heat specification, etc.
But for the wall boundary condition, why don't you use a thin wall where you specify the outer wall temperature (i.e. side away from flame), the wall (ceramic fiber)thickness, and the wall thermal conductivity. I am assuming you are including radiation so you also need to specify the wall emissivity - you should be able to find something reasonable by Googling it.
Good luck.
Old   November 4, 2005, 03:12
Andrea
I don't use radiation. If it's wrong, how can I set the radiation?
Thx
Old   November 4, 2005, 09:45
Mary
??? Radiation is the most important mechanism of heat transfer in a furnace
Old   November 4, 2005, 09:55
Andrea
Please give me some advise
Old   November 4, 2005, 14:57
Allan Walsh
A good start would be to use the P1 radiation model. It is quite simple but robust. For your gas mixture, use the WSGGM-cell based approach for calculating the absorption coefficient. (This is quite easy in Fluent).
Try a wall emissivity of about 0.5, using the BC set-up I suggested earlier, and see what you get.
Old   November 5, 2005, 04:00
Andrea
You are very kind, I tried in your ways and it's ok! Another question: in the wall I used in the thermal conditions the mixed ones. Now, where I can find a good value of heat transfert coefficient and heat generation rate? And then, do I have to use shell conductions? What's the difference by using it or not?
Thx very much Andrea
Old   November 7, 2005, 12:49
Allan Walsh
You should be able to find the thermal conductivity quite easily for your insulation material from a text book, by googling it, or using an estimated value for a similar material.
There should not be any heat generation (or sink) in the wall - the heat release is in the furnace cavity.
Don't use the shell wall boundary condtion - this is for a heat exchanger. Just specify the outer (cooler) wall temperature, wall thickness, wall thermal conductivity, and let Fluent do the 1-dimensional calculation for wall temperature at the furnace side.
Old   November 11, 2005, 04:37
Andrea
In species transport (methane air 2 steps)if I define the mixture thermal conductivity & viscosity as "ideal-gas mixing-law", what must I set in the thermal cond. & viscosity of each fluid (CO,CO2,AIR...)
Thx Andrea
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
wall heat flux between two fluid zone!!! Asghari FLUENT 2 August 25, 2006 11:11
wall heat flux Asghari FLUENT 2 August 24, 2006 12:58
Total heat through a wall massimo Siemens 0 December 22, 2002 13:25
