correct UDF code for unsteady pressure boundary
Old   November 2, 2005, 12:38
Default correct UDF code for unsteady pressure boundary
James W
I am trying to set the pressure on a pressure outlet boundary on a 3d pipe. The pressure is a pressure wave.
the magnitude of the pulse when measured using a monitor point by fluent is less than that calculated by the UDF.
I have my suspicions that the problem maybe due to the UDF code. Especially the section where it loops over the boundary - should this be different in 2d and 3d?
I will admit i am not fully up to spead on the UDF code and have adapted some from a 2d example i seen in a tutorial.
I have included the code below. If its not this then any other ideas, using the RSM model. unsteady coupled solver, 10 iterations per timestep. convergence seams good.
#include "udf.h"
DEFINE_PROFILE(unsteady_pressure, thread, position) {
float t, pressure; face_t f;
/* Get real flow time from fluent using RP_Get_Real command*/
t = RP_Get_Real("flow-time");
/* Set pressure dependant on time for pulse duration */
if (t<=0.00821) { pressure = 60000*sin(3.14159*t/0.00821); } else { pressure = 0; }
/* loop over the whole boundary condition */
begin_f_loop(f, thread) {
F_PROFILE(f, thread, position) = pressure; } end_f_loop(f, thread)
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Neumann Pressure Boundary Condition with UDF Balder Fluent UDF and Scheme Programming 8 July 6, 2012 12:21
How can I implement time varying pressure boundary condtion through UDF nacaairfoil FLUENT 0 October 11, 2011 14:03
pressure oscillation near pressure outlet boundary kino Main CFD Forum 5 April 13, 2011 12:03
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
