November 2, 2005, 09:41 |
Modifying geometry in GAMBIT
Hi, I have a solid geometry created in ProE. I imported it as a STEP file into GAMBIT. Then created a cylinder in GAMBIT and enclosed the solid in it. The solid is that of a valve frame with flanges and struts. I subtracted the volume of the solid from that of the cylinder to get the flow field within and around the valve frame (solid). Then meshed the subtracted volume directly.
Now I want to wrap leaflets around the flanges. The leaflets are polymeric materials and open and close according to the pulsatile flow. How can I create the presence of the leaflets and their movements in GAMBIT or FLUENT? Will GAMBIT treat the leaflet as a solid wall or something? I have the dimensions of the leaflet and the closing and flexing angles, etc. Also how can I simulate unsteady flow conditions in FLUENT? The flow is pulsatile and laminar? Do I need to use some kind of USER DEFINED FUNCTION? If so, how do I use that. Thanks in advance. Vidya |
Geometry of Tank and Rushton Turbine in Gambit | jawidnaik | ANSYS Meshing & Geometry | 1 | February 4, 2015 07:28 |
create turbine geometry with gambit | badlaine | ANSYS Meshing & Geometry | 2 | March 26, 2012 23:54 |
What can I employ to create geometry besides Gambit? | summer | ANSYS Meshing & Geometry | 2 | February 11, 2011 14:50 |
Need support for GAMBIT geometry | srbbd | FLOW-3D | 3 | March 12, 2009 19:16 |
problem about Importing geometry in Gambit | Hua Gu | FLUENT | 3 | April 2, 2002 14:24 |
