distance between particle and wall
Old   November 1, 2005, 13:32
Default distance between particle and wall
Worth
I'm using Fluent's discrete particle tracking model to validate particle deposition locations in an aerosol system. I get agreement with empirical results for most cases. However, I have trouble when the finite radius of the particle becomes important. That is, I need to calculate particle deposition when the surface of the discrete particle touches the wall as opposed to when the center touches the wall.
1. Is there a variable in Fluent for use in UDFs that will tell me the distance between the particle and the wall?
2. Is there an existing UDF that will do this. If not, any pointers on getting started will be helpful.
Thanks in advance. Worth
Old   November 17, 2005, 14:45
Default Re: distance between particle and wall
Jalal Istephan
Dear sir, I'm using Fluent to study the thermodynamic effect of cavitatin on NACA0012 and i have a problem which is: How can i know the distance between the surface of the airfoil and the cavity region. Please if you know any macro of udf regarding to this problem ,i'll be very happy to sent it to me.
Jalal A.Istephan
Old   June 13, 2009, 04:04
lele
yingfei1001 is on a distinguished road
x0=P_POS(p)[0]
x1=P_POS(p)[1]
x2=P_POS(p)[2]
you can get the position of the particle,then you can get the distance between the particle and surface!
yingfei1001 is offline   Reply With Quote
Hiting the wall by particle shchepan OpenFOAM Running, Solving & CFD 31 February 4, 2016 06:09
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Find a particle's distance to a wall gruber OpenFOAM 9 February 15, 2012 07:22
can cfx5/10 do particle near wall correction? steven CFX 0 March 1, 2006 16:04
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 04:56
