Hi!
I have a geometry partly filled with a porous medium (Fluid with option porous medium) that has a higher temp. than the fluid (air) crossing it. So, how can Fluent calculate the heat transfer from the porous to the fluid? I know the temp of the porous and the fluid, the wedded surface, the heat capacity and density and I have a guess about the overall heat transfer coefficient. Can Fluent calculate this? Is it necessary to write a UDF?? If yes, how should it look like? Any help is highly appreciated!!! Ralf |
Ok… now I figured out that Fluent offers source terms for any medium. So I guess for my case the energy term is necessary.
But there is another question: The value of the energy term Q is given in W/m3, does that mean, I have to take Q = HTC * a * (Tfluid â€" Tporous) (a is the wedded surface) How does Fluent handle the porosity in this case? Does Fluent take the volume of every cell times the porosity (say 0.8) and calculates the heat transfer Q in the cell??? And what is about radiation?? Can the temperatur of a hot (or cold) wall effect the temp of the material, the porous medium is made from?? Ralf |
Heat transfer within Porous Media | Twiti | CFX | 10 | January 15, 2021 08:13 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
heat transfer with porous block in fluent | Salhi Rachid | FLUENT | 2 | November 26, 2003 13:41 |
heat transfer with porous block in fluent | salhi | FLUENT | 1 | September 25, 2003 04:43 |
