October 27, 2005, 09:49 |
urgent: heat transfer fluid to solid
hi! i have to simulate a pipe flow with a heat transfer through the walls of the pipe. (aluminium pipe, outer temperature is constant) usually for something like that i created a rectangle in GAMBIT. then i definded the outer lines as walls, one line as inlet, one as outlet. this time I am asked to model the walls in 2D in gambit, not just as a line as before. so i did this. I drawed a shape that looks like three rectangles one upon the other. then i defined 8 of the lines as walls, one inlet, one outlet. then i defined three faces: the upper rectangle, the one in the middle and the lower one. after meshing each face i defined the middle face as "fluid" and the others as "solid".
is this generally right for this problem? because when i export this to fluent I have problems with setting the boundary conditions. I am able to set a constant temperature for the inner walls, which is not meant to be. when i calculate the results i just get constant temperatures in the wall and fluid, so probably there is no heat transfer between my wall and my fluid. can anyone help me? thank you |
October 28, 2005, 22:17 |
Re: urgent: heat transfer fluid to solid
Hi Marco, Why do you have to create rectangles in Gambit? You can draw edges and create faces instead from these edges..
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Plotting heat transfer Q in a fluid zone | booz | FLUENT | 0 | June 19, 2011 10:57 |
Solid / Fluid Heat Transfer | Koranten | FLUENT | 3 | March 19, 2011 07:21 |
radiation transfer between solid and fluid zone | shyang | FLUENT | 0 | August 13, 2008 12:45 |
modeling heat transfer betwwen fluid and solid | Al Mazdeh | CFX | 0 | March 13, 2008 10:35 |
