Can wemodify effective thermal conductivity by UDF |
In Phoenics CFD software, we can modify effecive thermal conductivity in energy equation by adjusting the thermal diffusivity. I want to know if we can do the same thing in FLUENT by UDF. The DEFINE_DIFFUSIVITY macro is not possible because it only can be used to specify the diffusivity for the species transport equations or user-defined scalar (UDS) transport equations.
Thanks a lot. |
Thermal diffusivity is modeled by
k+cp*turb_viscosity/Pr_Energy k is conductivity and cp specfific heat. You can set Prandtl number in the viscous panel either as constant value or udf. Unfortunatly there is no documentation about the needed macro (only for TKE and TDR Prandtl). In udf.h you can find (beside the two DEFINE_PRANDTL macros mention in the udf guide) three macros #define DEFINE_PRANDTL_O(name, c, t) real name(cell_t c, Thread *t) #define DEFINE_PRANDTL_T(name, c, t) real name(cell_t c, Thread *t) #define DEFINE_PRANDTL_T_WALL(name, c, t) real name(cell_t c, Thread *t) Maybe one of those will work. Good Luck RoM |
Rom, thank for your help.
I need one simple udf code for effective thermal conductivity of nanofluid | mvf | Fluent UDF and Scheme Programming | 1 | February 10, 2017 19:05 |
UDF for effective thermal conductivity | Rashmi | FLUENT | 1 | November 6, 2007 20:08 |
UDF for effective thermal conductivity | Mona | FLUENT | 2 | January 16, 2006 13:36 |
Effective thermal conductivity UDF - C_K_EFF?? | Craig | FLUENT | 4 | February 11, 2004 14:02 |
Porous Media Effective Thermal Conductivity | Greg Perkins | FLUENT | 3 | August 5, 2001 21:53 |
