VOF Patching fluids at an angle?
Old   October 26, 2005, 21:58
Default VOF Patching fluids at an angle?
Brian
This may be a dumb question but here it goes:
I am trying to simulate a box moving in air at a constant velocity and slamming into water. (Making use of centerline symmetry as well) I am also trying to simulate a triangular wedge doing the same thing. Now, I can mesh/simulate the box with some success by raising the water level instead at a constant velocity at the inlet using VOF. The mesh is all rectangular and nice. Instead of making a new mesh for the triangle, I thought it would be easier to make the water level at an angle instead since the problem is symmetric. However, I cannot seem to patch the water level at an angle. Fluent only lets you mark regions that are recangular. Is there a way around this or do I need to keep making new meshes for all the different angles?
Also, while I'm on a roll can someone verify my BC's/methodology? To help visualize the domain think of axisymmetric flow over a sphere. Only half the sphere needs to be modeled with a symmetry boundary. I basically have the same thing but half a box is there instead of a circle and it's NOT axisymmetric. The bottom is a velocity inlet, top is a pressure outlet, right is a wall, left is a symmetry boundary and the box/wedge is specified as a wall on the left boundary smack dab in the middle. The model is incompressible/inviscid and water is patched in just below the box and the water level rises to simulate the box falling as mentioned above. I am trying to calculate the maximum pressure along the bottom edge of the box. Should I be monitoring the maximum vertex value of static pressure on the bottom edge? Any suggestions regarding this or VOF with this problem would be greatly appreciated!!
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 06:38
VOF - Patching friends.sk FLUENT 6 April 2, 2010 02:56
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
