Paradox in parallel processing
Old   October 26, 2005, 06:36
Default Paradox in parallel processing
Vagelis
Hi users of Fluent,
I simulate in 1 node processor and the system load is full. When I simulate in a parallel processing with 2 nodes I notice that the system load for the Fluent process is approximately 45% in each node. Why is this happening? Is this right? I would be grateful if someone could explain to me this paradox!
My system configuration is: Parallel processing, 2 nodes, Fluent 6.2.16, socket protocol, Linux 64bit, opteron CPU, 2Gb RAM, Gigabit, case file appr. 700000cells
Thanks,
Vaggelis
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 10:25
multiphase solver - parallel processing - GAMG thibault_pringuey OpenFOAM Programming & Development 2 August 27, 2013 23:03
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 06:08
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
