Running Multiple cases over night
Old   October 25, 2005, 08:53
Default Running Multiple cases over night
Michael Bo Hansen
Does anybody know how to set up a batch run of multiple fluent cases? Say I have 3 case files which I each want to run over night but I only got one license. So when one is finished another starts up. I'm running on windows. Kid regards Michael Bo
Old   October 25, 2005, 10:31
Default Re: Running Multiple cases over night
kp
try doing it with a scheme file.
Old   October 25, 2005, 11:04
HVN
You should use a batch file with input file. Normally it's explain in the manual.
Old   October 26, 2005, 03:31
Michael Bo Hansen
Thanks. But I haven't found it in the manual. I'll keep looking
Old   October 26, 2005, 03:59
mAx
Hi, here is one example of 2 calculations running in batch. Edit a file, say batch.jou with: rcd 10mm_v2_11cst.cas yes it 3000 wd 10mm_v2_11cst.dat yes
rcd 10mm_v2_80cst.cas yes it 3000 wd 10mm_v2_80cst.dat yes
Be carefull when you edit this text, especially under windows... if you decide after that to read this journal file under unix.... it will scratch because of the windows edit tool. With Ultra Edit...there is no problem. mAx
Old   October 26, 2005, 10:17
Michael Bo Hansen
Thanks! It was just what I was looking for!
Old   October 26, 2005, 12:18
Riaan
Try a Fluent Journal file.
Under Fluent File- Start Journal File, then read and solve all your cases for 2-3 iterations, and write case and data. The Stop Journal file.
Find the journal file on your hard drive and change the number of itterations to the number you want i.e. 2000 per case.
Load Fluent, and Read Journal File - it will then do exactly what you did previously, except with the correct number of itterations for each case.
Old   October 26, 2005, 21:22
zxaar
hey i once did a loooong ago, i used journal, i will try to find some help for you.
Old   October 26, 2005, 21:36
zxaar
this is how it is:
file read-case-data xxx1.cas solve dual-time-iterate yyy1 file write-case-data zzz1.cas file read-case-data xxx2.cas yes (comment: for discard cas dialog) solve dual-time-iterate yyy2 file write-case-data zzz2.cas
for steady case i think it will be solve iterate yyy1 but i am not sure, my case was unsteady. hope it helps.
Old   May 7, 2009, 04:10
sourplum
sourplum is on a distinguished road
Send a message via Yahoo to sourplum Send a message via Skype™ to sourplum
This thread help me a lot
thanks you so much =)
regards,
safuan
sourplum is offline   Reply With Quote
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 05:18
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
applying the same setting to multiple cases Ralf Schmidt FLUENT 3 November 4, 2005 15:06
How to run OpenFOAM on multiple licensed hosts maritozzo OpenFOAM Installation 1 September 29, 2005 14:13
Standard CFD test cases? Damon Qualski Main CFD Forum 1 April 10, 2003 15:10
